S2L Frequency Flash
S2L Frequency Flash
The SCE Frequency Flash effect generates a pulse effect which is running synchronously to the audio frequencies.
The effect shows a color when a high level between the two selected frequencies is reached. Afterwards, the selected color will be dimmed with a certain "Fade" duration. When a high level is reached once more, the color will be set to 100% again.
BandIn order to be able to specify how the effect should work, MADRIX offers the user to set a frequency "Band". In this way, the software analyzes the music with regard to certain areas/frequencies (in Herz). The left box represents the lowest frequency, the right one the highest. In the example shown above, the frequency spectrum includes everything between 8Hz and 102Hz. Bass tones (usually 8Hz - 135Hz) are especially suited for this effect.
"Sensitivity" controls the sensitivity of the audio analysis. It works like an audio filter. The more you move the fader to the right, the less drops will be displayed. The sensitivity will increase and only the most important analytical data will be used. The numerical values for Sens have to be in the area from 0 – 100.
