S2L EQ Tubes
S2L EQ Tubes
The S2L EQ Tubes effect delivers an equalizer-like effect displayed as horizontal or vertical lines.
You can simply choose a color by using your mouse or keyboard.
S2L EQ Tubes Example
"BPM" sets up the speed with which the drops are being displayed and updated. If you would like to have slow movements (updates) move the fader to the left, or put in low numerical values. Values in a range from 1 to 9999 are supported. If you move the fade to the right, the update speed increases and drops move faster.
"Fade (BPM)" determines the fade-out time of lines. The higher the value, the faster lines will vanish.
LinesThese two buttons decide if lines should be displayed in horizontal or vertical order.
AcrossThis button enables horizontal and vertical lines to be shown at the same time, i.e. crossed.
You can use the "Amplify" function as a visual amplifier of the audio signal. Values will be displayed more intensely as a result. The more you move the fader to the right, the stronger will be the visual amplification of single signals.
"Bands" determines the number of equalizer bands shown. If you have a matrix size with 50 x 50 pixels for example, you can make use of a 50-band equalizer at maximum. Additionally, you may "Invert" or "Mirror" the effect.
Use Audio Level If you have activated "Use Level (db)", this effect illustrates the (volume) level of the music and its frequencies. MADRIX uses the color that has been selected by you, when a certain level in the music has been reached.
