M2L Interval Tubes
M2L Interval Tubes
The Music2Light interval tube effect renders intervals included in the music in form of tubes.
The MADRIX music analysis works with the following criteria in this effect: included intervals.
M2L Interval Tubes Example
As set up possibilities you have the color values for the color of the tubes. The value from 0 to 255 can be entered. With the help of the fader box you can also enter the colors with your mouse.
"BPM" sets up the speed with which the effect is displayed and updated. If you would like to have slow movements (updates) move the fader to the left, or put in low numerical values. Values in a range from 1 to 9999 are supported. If you move the fade to the right, the update speed increases and the effect moves faster.
"Fade" determines the fade-out time of tubes. The higher the value, the faster tubes will vanish.
"Width" defines the width of tubes. An input value of 1 corresponds to 1 pixel for one tube. Larger numbers mean more pixels per tube.
Line ModesThese option buttons decide if tubes are displayed horizontally, vertically, or both.
Conclusion: As soon as it is possible to analyze one or more intervals, they will be displayed as tubes in the color you set up.
