M2L Single Tone Shapes |
"Fade (BPM)" sets up the speed with which the effect is displayed and updated. If you would like to have slow movements (updates) move the fader to the left, or put in low numerical values. Values in a range from 1 to 9999 are supported. If you move the fade to the right, the update speed increases and the effect moves faster. "Sensitivity" controls the sensitivity of the audio analysis. It works like an audio filter. The more you move the fader to the right, the less drops will be displayed. The sensitivity will increase and only the most important analytical data will be used. The numerical values for Sens have to be in the area from 0 – 100. "Width" decides over the width of objects. An input value of 1 corresponds to 1 pixel for one tube. Larger numbers mean more larger objects for a single tone. "Pitch" allows to adjust the spacing between objects. "Border" defines if objects are rendered with an additional border, which makes them appear bigger.
Conclusion: As soon as it is possible to analyze one or more intervals, they will be displayed the color you set up.
