General Features
<< Click To Display Table Of Contents >> You Are Here: Web Configuration > General Features |
▪MADRIX AURA can manage a maximum of 1000 Scenes.
▪MADRIX AURA can manage a maximum of 1000 Cues.
Character Encoding
MADRIX AURA supports UTF-8 character encoding.
This means that basically characters of any language can be shown in the web configuration. This is necessary since file names [of Scene Files] can be set outside of the web configuration of the device itself, such as MADRIX 5 or changes on the file system of the SD card.
▪However, this does not mean that you can use UTF-8 characters in names of Cue Lists or any other strings of the web configuration.
Also, the following characters will usually lead to issues, since they are used by the file system. It is recommended to avoid using them:
▪[Tab] by using the tabulator key
| MADRIX AURA User Manual 4.01. |
