Step 5) Converting Files |
Step 5) Converting Files Overview Call up the Recording dialog again. In MADRIX, please go to the menu 'Window' -> 'Recording' (or 'Ctrl+Alt+R'). First, select your MADRIX Record File (*.mrec) in the list. Please only select one file from the list! Second, switch to the tab 'PLEXUS Conversion'. The tab 'PLEXUS Conversion' allows you to prepare the conversion. You can edit and configure how a MADRIX Record File (*.mrec) is converted into a DMX Data File (*.dxd).
Preparing The Conversion Please make sure that your virtual matrix (Patch) is configured correctly before generating DMX Data Files (*.dxd). Note: The PLEXUS Conversion tab only factors in the settings of the Patch and not the settings of the Device Manager in MADRIX.
You may edit the each entry. 'Author', 'Scene Name', 'File Name' can be changed. They define how the new DMX Data File will be named after the conversion. Select an entry. Double-click on the particular column and enter the values or characters using the keyboard. Use Enter to apply your changes. Please make sure that your 'File Name' has the ending '*.dxd'. 'DMX 1' defines which DMX universe of your virtual matrix (Patch) will be used for the first output port of your PLEXUS. Select an entry. Perform a double-click and simply enter the number of the universe. Use Enter to apply the changes. Select 'No' if the output port should be deactivated. 'DMX 2' defines which DMX universe of your virtual matrix (Patch) will be used for the second output port of your PLEXUS. Select an entry. Perform a double-click and simply enter the number of the universe. Use Enter to apply the changes. Select 'No' if the output port should be deactivated. 'Use Master Values' can be activated if you have used the Master Fader during recording. Then, your converted record will include the brightness levels set by the Master Fader during the recording. Leave the option unchanged if your did not use the Master Fader during recording. Please note: If your are using more than 2 DMX universes and more than 1 MADRIX PLEXUS at the same time, please make sure to have a list entry for each PLEXUS (You will need 1 list entry for each PLEXUS of your installation).
Example: We have created a Patch for 6 DMX universes and we are using 3 MADRIX PLEXUS. PLEXUS number 1 should play DMX universe 1 and 2, PLEXUS number 2 should play DMX universe 3 and 4, PLEXUS number 3 should play DMX universe 5 and 6. Then, we need to create 3 list entries or use the 'Auto' button. (We will also have to generate 3 DMX Data Files (*.dxd) in the next step.)
Generating DMX Data Files (*.dxd) Please make sure that your virtual matrix (Patch) is configured correctly before generating DMX Data Files (*.dxd). 1. Select your MADRIX Record File (*.mrec) in the list. Please only select one file! 2. Open the tab 'Edit Record' to double-check the recording (e.g. check the colors or the length of the effect). 3. Open the tab 'PLEXUS Conversion' and press 'Auto' to quickly proceed. Or configure your list entry or several entries manually. 4. Press 'Generate' to convert the MADRIX Record File (*.mrec) into one or multiple DMX Data Files (*.dxd). 5. The newly create DMX Data Files (*.dxd) will be added to the above list.
Please note:
Warnings: When generating *.dxd files, you may encounter two messages. 1) As described above, you need to configure your virtual matrix (Patch Size) correctly, before generating DMX Data Files. This message box is a reminder to check if your Patch settings are configured correctly. Press 'Yes' if you would like to proceed with your current settings. Press 'No' if you would like to change your settings. 2) As described above, the maximum recommended frame rate for the MADRIX PLEXUS is 40 FPS (a frame time of 25ms). This message box is a reminder to check if your frame rate settings are configured correctly. Press 'Yes' if you would like to continue with your current settings. Press 'No' if you would like to change your settings.
