MADRIX PLEXUS (Hardware) |
In general, this device is designed to be operated as a hardware control interface to be connected towards various types of controllable lights / lighting controllers via DMX512 (USB-to-DMX) or Art-Net (DMX-over-Ethernet). Do not use the interface for any other, deviant purpose. The device can be connected to and disconnected from the PC during use and without a reboot (Hot Swapping & Plug and Play). Multiple interfaces can be used at the same time. Please mind the correct supply of power in this case. Please read the following subtopics to learn more about MADRIX PLEXUS.
