Loading And Enabling Drivers In MADRIX
Enabling USB Drivers In MADRIX
Please note: Enabled USB drivers are required for Live Mode via USB and the USB connection from your PC to the device.
Please make sure to activate the driver for the USB connection in the MADRIX Options. To access the Options of MADRIX, first go to the menu 'Preferences' -> 'Options' (or 'Ctrl+Alt+O'). Second, select the tab 'Devices (USB/PCI)'.
Devices (USB/PCI)
Enable the 'MADRIX  PLEXUS interfaces' driver and press 'Apply'.
Close the dialog with 'OK'.
Enabling Network Drivers In MADRIX
Please note: Enabled network drivers (PLEXUS Networking) are required for the Ethernet connection from your PC to the device.
Please make sure to activate the driver for the Ethernet (network) connection in the MADRIX Options. To access the Options of MADRIX, please press 'Ctrl+Alt+O' or go to the menu 'Preferences' -> 'Options'. Now go to the tab 'Devices (Network)'.
Network Driver
Select 'Enable PLEXUS / LUNA Networking' and press 'Apply'. Close the dialog with 'OK'.
