The S2L Level Color effect refers to the level of music. It puts out the color that has been selected by you when a certain level in the music has been reached.
After that the color is being dimmed with the "Fade" duration that has been set. A high level sets the color to 100%.
The speed value ("BPM") let's you determine how close the audio analysis correlates to the music. Higher speeds are suitable for electronic, beat-intense music, while classical music benefits from lower values.
If you activate the "Mono" switch, you will have a mono audio analysis using only 1 audio channel.
Four arrow buttons allow you to alter the direction and starting point of the effect. Press the downward arrow if you want the effect to be displayed from top to bottom, for example.
The effect includes a special function for setting BPM manually. If you want to attain synchronous movements of effects to the beat of the music, press the "Tap" button. Press this button at least four times in a row according to the beat of the music (1/4 notes). MADRIX will calculate the BPM value subsequently.
