Vestax VCI-100 [MIDI Map]
  Previous  Next
Vestax VCI-100 - MIDI Map
[27] Mode: Layer / Storage
(Storage Mode = light on)
Mode: Layer
Mode: Storage
[25] + [42] Layer Submaster
[25] + [42] Storage Place Submaster
[26] + [42] Layer Opacity
[42] Frame ID
[42] Switch Layers
[48] + [42] Storage ID S1 S256
[49] + [42] Layer UP/DOWN
[49] + [42] Storage Place P1 P256
[1] Speed Master Deck A / Deck B
[19] Color Filter color WHITE
[47] Speed Master Pause (Hold)
[5] Cue List Stop
[22] Crossfader Automatic Fade
[50] Fade Type Cross-fade
[6] Cue List Back
[23] Main Output Freeze
[51] Fade Type White-fade
[7] Cue List Open/Close
[24] Cue Storage Place Deck A / Deck B
[52] Fade Type Black-fade
[8] Cue List Go
[28] Crossfader Skip to Deck A / Deck B
[53] Fade Type Color-Fade
[9] Cue List Go + Start
[29] Must be value “mas.”! If “A” or “B” is selected, select “mas.”, then disconnect and reconnect the VCI100.
[14] Crossfader Fade Time
[43] Master
[16] Color Filter color RED
[44] Audio Input Level
[17] Color Filter color GREEN
[45] Crossfader
[18] Color Filter color BLUE
[46] Speed Master Pause (Permanently)
MADRIX 5.5.
 Previous   Next
