Omnitronic MMC-1 [MIDI Map]
Please power on the console with every new start!
[21 B HOLD] + [37] Mode: Color Filter (Default)
[21 A HOLD] + [36] Mode: Color-Fade
[39] Color RED for Color Filter or Color-Fade
[40] Color GREEN for Color Filter or Color-Fade
[41] Color BLUE for Color Filter or Color-Fade
[42] Color WHITE for Color Filter or Color-Fade
[22]
[22 PUSH]
[2] Mode 1
Layer Opacity (Deck A / Deck B)
Layer Opacity Reset
[3] Mode 2
Layer Submaster (Deck A / Deck B)
Layer Submaster Reset
[4] Mode 3
Layer Mix Mode UP/DOWN (Deck A / Deck B)
Layer Mix Mode Reset
[5] Mode 4
[1] Power On
[21 HOLD] + [19] Cue List Open/Close
[31] Speed Master Pause (Permanently) (Deck A / Deck B)
[10] Layer 1 (Deck A / Deck B)
[21 HOLD] + [20] Cue List Back
[32 HOLD] Speed Master Pause (Hold) (Deck A / Deck B)
[11] Layer 2 (Deck A / Deck B)
[23] Storage Place Submaster (Deck A / Deck B)
[33] Storage ID DOWN (Deck A / Deck B)
[12] Layer 3 (Deck A / Deck B)
[23 PUSH] Storage Place Submaster Reset (Deck A / Deck B)
[34] Storage ID UP (Deck A / Deck B)
[13] Layer 4 (Deck A / Deck B)
[24] Storage Place UP/DOWN (Deck A / Deck B)
[35] Speed Master (Deck A / Deck B)
[14] Layer DOWN (Deck A / Deck B)
[21 HOLD] + [24] Skip 5 Storage Places UP/DOWN (Deck A / Deck B)
[36] Crossfader Skip to Left
[15] Layer UP (Deck A / Deck B)
[24 PUSH] Storage Place P1 (Deck A / Deck B)
[37] Crossfader Skip to Right
[16] Layer Solo Mode (Deck A / Deck B)
[25] Cue List Play/Pause
[38] Crossfader Fade Type
[17] Layer Blind Mode (Deck A / Deck B)
[26] Cue List Go
[43] Crossfader Fade Time
[18] Solo Mode/Blind Mode OFF
[27] Cue List Open/Close
[45] Master
[19] Cue Storage Place (Deck A / Deck B)
[28] Cue List Back
[46] Audio Input Level
[20] Cue List Go
[29] Frame ID (Deck A / Deck B)
[47] Crossfader
[30] Speed Master Reset (Deck A / Deck B)
