Numark NuVJ [MIDI Map]
Numark NuVJ - MIDI Map
[9] Mode: Layer / Storage
Mode: Layer
Mode: Storage
[1] Layer 1 – 9 (Deck A / Deck B)
[1] Storage Place P1 – P9 (Deck A / Deck B)
[2] + [4] Layer UP/DOWN (Deck A / Deck B)
[2 + 4 HOLD] Frame ID UP / Frame ID DOWN (Deck A / Deck B)
[4] Speed Master Pause ON/OFF (Deck A / Deck B)
[6] Layer Mix Mode UP/DOWN (Deck A / Deck B)
[6] Storage Place UP/DOWN (Deck A / Deck B)
[6 PUSH] Layer Mix Mode Reset
[6 PUSH and TURN] Storage ID UP/DOWN (Deck A / Deck B)
[7] Layer Submaster (Deck A / Deck B)
[7] Storage Place Submaster (Deck A / Deck B)
[8] Layer Opacity (Deck A / Deck B)
[8] Speed Master (Deck A / Deck B)
[10] Layer Submaster Reset (Deck A / Deck B)
[10] Storage Place Submaster Reset (Deck A / Deck B)
[11] Layer Opacity Reset (Deck A / Deck B)
[11] Speed Master Reset (Deck A / Deck B)
GLOBAL
                         [3] Master / Audio Input Level
                         [5] Cue List Back/Go
                         [13] Crossfader Fade type UP/DOWN
                         [14] Cue List Open/Close
                         [15] Color Filter color RED
                         [17] Cue List Play/Pause
                         [18] Color Filter color GREEN
                         [19] Color Filter color WHITE
                         [20] Crossfader Automatic Fade
                         [21] Color Filter color BLUE
                         [22] Crossfader
                         [24] Crossfader Fade Time
