MIDI Universal [MIDI Map]
Do not use MIDI channels/controllers that are currently not assigned. These entries are reserved for future features.
MIDI Message Type 0xb0 [Controller 0xb, Control Change, Channel 1]
Controller
Value
#00
Storage Place Deck A
#01
Storage Place Deck B
#02
Storage Place Deck A +Fade
#03
Storage Place Deck B +Fade
#04
Storage Place Deck A UP
#05
Storage Place Deck A DOWN
#06
Storage Place Deck B UP
#07
Storage Place Deck B DOWN
#08
Storage Place Deck A UP +Fade
#09
Storage Place Deck A DOWN +Fade
#0A
Storage Place Deck B UP +Fade
#0B
Storage Place Deck B DOWN +Fade
#10
Storage Place Submaster Deck A
#11
Storage Place Submaster Deck B
#12
Storage Place Submaster Deck A UP
#13
Storage Place Submaster Deck A DOWN
#14
Storage Place Submaster Deck B UP
#15
Storage Place Submaster Deck B DOWN
#20
Speed Master Deck A
#21
Speed Master Deck A UP
#22
Speed Master Deck A DOWN
#23
Speed Master Deck A Reset
#24
Speed Master Deck A Pause
#25
Speed Master Deck A Pause (Hold)
#26
Speed Master Deck A Play
#28
Speed Master Deck B
#29
Speed Master Deck B UP
#2A
Speed Master Deck B Down
#2B
Speed Master Deck B Reset
#2C
Speed Master Deck B Pause
#2D
Speed Master Deck B Pause (Hold)
#2E
Speed Master Deck B Play
#30
Storage Deck A Frame ID UP
#31
Storage Deck A Frame ID DOWN
#32
Storage Deck B Frame ID UP
#33
Storage Deck B Frame ID DOWN
#3A
Main Output Freeze ON
#3B
Main Output Freeze OFF
#3C
Main Output Freeze (Hold)
#40
Layer Deck A
#41
Layer Deck B
#42
Layer Deck A UP
#43
Layer Deck B DOWN
#44
Layer Deck B UP
#45
Layer Deck B DOWN
#50
Layer Opacity Deck A
#51
Layer Opacity Deck B
#52
Layer Opacity Deck A UP
#53
Layer Opacity Deck A DOWN
#54
Layer Opacity Deck B UP
#55
Layer Opacity Deck B DOWN
#60
Layer Submaster Deck A
#61
Layer Submaster Deck B
#62
Layer Submaster Deck A UP
#63
Layer Submaster Deck A DOWN
#64
Layer Submaster Deck B UP
#65
Layer Submaster Deck B DOWN
#70
Layer Mix Mode Deck A
#71
Layer Mix Mode Deck B
#72
Layer Mix Mode Deck A UP
#73
Layer Mix Mode Deck A DOWN
#74
Layer Mix Mode Deck B UP
#75
Layer Mix Mode Deck B DOWN
MIDI Message Type 0xb1 [Controller 0xb, Control Change, Channel 2]
Controller
Value
#00
Layer Frame ID Deck A UP
#01
Layer Frame ID Deck A DOWN
#02
Layer Frame ID Deck B UP
#03
Layer Frame ID Deck B DOWN
#10
Crossfader Fade Time
#12
Crossfader Automatic Fade
#13
Crossfader
#14
Crossfader Step Deck A
#15
Crossfader Step Deck B
#16
Crossfader Skip to Left
#17
Crossfader Skip to Right
#1A
Master
#1B
Master UP
#1C
Master Down
#20
Crossfader Fade Type UP
#21
Crossfader Fade Type DOWN
#22
Crossfader Fade Type Cross-Fade
#23
Crossfader Fade Type White-Fade
#24
Crossfader Fade Type Black-Fade
#25
Crossfader Fade Type Color-Fade
#40
Color-Fade color RED
#41
Color-Fade color RED UP
#42
Color-Fade color RED DOWN
#43
Color-Fade color GREEN
#44
Color-Fade color GREEN UP
#45
Color-Fade color GREEN DOWN
#46
Color-Fade color BLUE
#47
Color-Fade color BLUE UP
#48
Color-Fade color BLUE DOWN
#49
Color-Fade color WHITE
#4A
Color-Fade color WHITE UP
#4B
Color-Fade color WHITE DOWN
#50
Cue Storage Place Deck A
#51
Cue Storage Place Deck B
#52
Remove Cue List Entry VALUE
#53
Remove CURRENT Cue List Entry
#54
Cue List Play
#55
Cue List Stop
#56
Cue List Play/Pause
#57
Cue List Go
#58
Cue List Back
#59
PLACEHOLDER
#5A
Cue List Goto
#5C
Cue List Open
#5D
Cue List Close
#5E
Cue List Open/Close
#60
Audio Input Unmute
#61
Audio Input Mute
#62
Audio Input Mute/Unmute
#63
Audio Output Unmute
#64
Audio Output Mute
#65
Audio Output Mute/Unmute
#66
Audio Input Level
#67
Audio Input Level UP
#68
Audio Input Level DOWN
#70
Audio Output Level
#71
Audio Output Level UP
#72
Audio Output Level DOWN
#73
Audio Input Automatic Gain Control
#74
Color Filter color RED
#75
Color Filter color RED UP
#76
Color Filter color RED DOWN
#77
Color Filter color GREEN
#78
Color Filter color GREEN UP
#79
Color Filter color GREEN DOWN
#7A
Color Filter color BLUE
#7B
Color Filter color BLUE UP
#7C
Color Filter color BLUE DOWN
#7D
Color Filter color WHITE
#7E
Color Filter color WHITE UP
#7F
Color Filter color WHITE DOWN
MIDI Message Type 0x80/0x90 [Note OFF/ON, Channels 1 - 16]
#0
Storage Place Deck A P1
#60
Storage Place Deck B P1
#59
Storage Place Deck A P60
#119
Storage Place Deck B P60
#124
#126
#125
#127
