MADRIX KEY Firmware Update
The MADRIX KEY itself is a technologically advanced device. That is why it also comes with its own firmware.
In order to function correctly, the MADRIX 5 Software requires a minimum firmware version for the MADRIX KEY.
Make sure that your MADRIX KEY uses the correct firmware. You can update the MADRIX KEY firmware in different ways.
MADRIX 5 Software Installation
Windows Start Menu
First Software Start
Help Menu
During the MADRIX 5 Software setup, you can choose to automatically update all connected USB software protection dongles.
Make sure to select MADRIX KEY Firmware Update
[Deselect it if you don't want to update any connected USB security dongles now.]
Windows Start Menu
You can find the link to the MADRIX 5 KEY Firmware Updater in the Windows Start menu:
In Windows 10, go to Start > MADRIX 5 > MADRIX 5 KEY Firmware Updater
When starting a new MADRIX 5 Software version for the first time, the MADRIX 5 Software will automatically check if the connected MADRIX KEY uses an older firmware version.
Click Yes in order to continue and update all connected USB software protection dongles.
- Only connect MADRIX KEYs that should be udpated.
- Unplug all dongles that should not be updated.
- Do not unplug any dongles during the update process.
Click No if you do not wish to continue to update the connected USB software protection dongles.
- Note: Your MADRIX 5 Software will not be able to recognize any MADRIX KEY that uses a firmware that is older than the required firmware version.
Help Menu
You can also find the link to the MADRIX 5 KEY Firmware Updater in the MADRIX 5 Software:
Go to the menu Help > MADRIX KEY > Update MADRIX KEY Firmware...
