Elation Professional MIDICON [MIDI Map]
  Previous  Next
Elation Professional MIDICON - MIDI Map
[3] Cue Storage Place Deck A
[52] Speed Master Deck B Pause
[8] Cue Storage Place Deck B
[56] Cue List Open/Close
[11] Layer Deck A DOWN
[57] Cue List Play/Pause
[12] Layer Deck A UP
[62] Storage Place Deck A UP (Arrow key behavior)
[13] Color-Fade color RED (ON/OFF)
[64] Storage ID Deck A DOWN
[14] Color-Fade color GREEN (ON/OFF)
[65] Storage ID Deck A UP
[15] Color-Fade color BLUE (ON/OFF)
[67] Storage Place Deck B UP (Arrow key behavior)
[16] Color-Fade color WHITE (ON/OFF)
[69] Storage Place Deck A LEFT (Arrow key behavior)
[17] Layer Deck B DOWN
[70] Storage Place Deck A DOWN (Arrow key behavior)
[18] Layer Deck B UP
[71] Storage Place Deck A RIGHT (Arrow key behavior)
[19] Layer Deck A Solo Mode
[72] Storage ID Deck B DOWN
[20] Layer Deck A Mix Mode UP
[73] Storage ID Deck B UP
[25] Layer Deck B Mix Mode UP
[74] Storage Place Deck B LEFT (Arrow key behavior)
[26] Layer Deck B Solo Mode
[75] Storage Place Deck A DOWN (Arrow key behavior)
[27] Layer Deck A Blind Mode
[76] Storage Place Deck A RIGHT (Arrow key behavior)
[28] Layer Deck A Mix Mode DOWN
[77] Speed Master Deck A UP/DOWN
[33] Layer Deck B Mix Mode DOWN
[77 Push] Speed Master Deck A Reset
[34] Layer Deck B Blind Mode
[78] Crossfader
[35] Blackout
[78] + [89] Crossfader Fade Time UP/DOWN
[36] Layer Deck A Opacity
[78] + [91] Audio Input Level UP/DOWN
[37] Layer Deck A Submaster
[78 Push] Crossfader Automatic Fade
[38] Color Filter color RED
[79] Speed Master Deck B UP/DOWN
[39] Color Filter color GREEN
[79 Push] Speed Master Deck B Reset
[40] Color Filter color BLUE
[80] Speed Master Deck A Pause (Hold)
[41] Color Filter color WHITE
[82] Crossfader Skip To Left
[42] Layer Deck B Submaster
[83] Crossfader Skip To Right
[43] Layer Deck B Opacity
[85] Speed Master Deck B Pause (Hold)
[44] Master
[86] Main Output Freeze (Hold)
[45] Speed Master Deck A Pause
[87] Main Output Freeze (Permanently)
[48] Cue List Go
[88] Crossfader Fade Type DOWN
[49] Cue List Back
[90] Audio Input Mute/Unmute
MADRIX 5.5.
 Previous   Next
