SCE Tubes
SCE Tubes displays various kinds of tubes at various positions.
BPM - Defines the speed. The default value is 1200. Valid values range from 0 to 9999.
Fade - Defines how fast MADRIX displays the effect [in %]. The default value is 60. Valid values range from 1 to 3000.
Size 1 - Defines the first size of tubes depending on the direction [in % of the Matrix Size]. The default value is 10. Valid values range from 0.01 to 100.
Pitch 1 - Defines the first distance between tubes depending on the direction [in % of the Matrix Size]. The default value is 10. Valid values range from 0.01 to 100.
Size 2 - Defines the second size of tubes depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100.
Pitch 2 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100.
Alpha Mix - Defines the upper limit of how much alpha is added to each object. Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100.
Count - Defines the number of objects. The default value is 1. Valid values range from 1 to 9999.
Vertical Mode - Activates or deactivates the use of vertical objects. All 3 modes can be used at the same time.
Horizontal Mode - Activates or deactivates the use of horizontal objects. All 3 modes can be used at the same time.
Depth Mode - Activates or deactivates the use of objects in the depth. All 3 modes can be used at the same time.
Mode - Allows you to choose the mode in which way objects are generated [Random, Linear, or Ping Pong]. The default Mode is Random.
