SCE Fill Snake
SCE Fill Snake fills the matrix in a snake-like mode.
[In MADRIX 2, SCE Fill Snake was part of SCE Color Fill.]
Fill Time - Defines the time how long it takes to fill the complete LED matrix with shapes [in s]. The default value is 5. Valid values range from 0.01 to 3600.
Duration - Defines the time the complete matrix is shown in solid color until the next round of objects begins to fill the matrix [in s]. The default value is 1. Valid values range from 0 to 3600.
Size - Defines the size of objects [Width, Height, Depth]. The default values are 10, 10, 10. Valid values range from 0.01 to 1000.
Pitch - Defines the distance between objects for all 3 axes [in % of the Matrix Size]. The default values are 10, 10, 10. Valid values range from 0 to 100.
Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 0.01. Valid values range from 0.01 to 100.
Position Origin Type - Defines the point of origin of Shapes [and hence their relative position].
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default Shape is Rectangle Filled.
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [, 90°, 180°, 270°, Random].
Start Corner - Defines where the snake movements starts [Front Top Left, Front Top Right, Front Bottom Left, Front Bottom Right, Back Top Left, Back Top Right, Back Bottom Left, Back Bottom Right]. This setting is available for 2D, but only in 3D all options are viable.
Orientation Mode - Defines the general movement direction [XYZ Orientation, XZY Orientation YXZ Orientation, YZX Orientation, ZYX Orientation, ZXY Orientation]. This setting is available for 2D, but only in 3D all options are viable.
Circle Mode - Activates a circular snake movement.
Center Mode - Starts movement from the center instead of the outer edge.
Mirror Mode - Duplicates the effect by mirroring it.
