S2L Waveform
Context Menu
S2L Waveform displays the audio input graphically. It is a timeline representation.
Color - Defines the color using a Color Gradient control. The default color is Red, Yellow, Green, Cyan, Blue, Magenta.
BPM - Defines the speed. The default speed is 60. You can either use BPM or Time Slot. Valid values range from 0 to 9999.
Time Slot - Defines the time interval [in s]. The default value is 1. You can either use BPM or Time Slot. Valid values range from 0.01 to 9999.
Direction/Mode - Allows you to choose the direction, including Look-At Type. This includes all directions for 2D and 3D mode. This heavily influences the visual outcome of the effect. The default Direction is Left. Learn more »Using Directions
Channel - Allows you to choose the displayed audio channels [Stereo, Mono, Left, Right]. The default value is Mono.
Context Menu
A context menu allows you to quickly make changes to the colors.
Right Mouse Click - Click with your right mouse button on the color gradient to call up the context menu.
Open... - Loads a previously saved Color Table file from an external file [of the file type *.mctx].
Save... - Saves the current colors as a Color Table file [of the file type *.mctx].
Copy - Copies the current colors into the clipboard as a duplicate.
Paste - Applies all colors from the clipboard to the currently focused color control [Colors, M2L Colors].
Defaults - Restores all default gradient colors.
MADRIX 3.6i
