Vestax VCI-100 - MIDI Map
[27] Switch to Layer mode / Storage mode
(Storage mode = light on)
LAYER MODE
STORAGE MODE
[25] + [42] Layer Submaster
[25] + [42] Storage Submaster
[26] + [42] Layer Opacity
[42] Layer Frame ID
[42] Storage Frame ID
[49] + [42] Layer UP/DOWN
[49] + [42] Storage Places 1 -60
[1] Speed Master A/B
[14] Fade time
[43] Master Fader
[5] Cue List Stop
[16] Color Filter color RED
[44] Audio level
[6] Cue List Back
[17] Color Filter color GREEN
[45] Crossfader
[7] Cue List Open/Close
[18] Color Filter color BLUE
[46] Speed Master PAUSE permanently
[8] Cue List GO
[19] Color Filter color WHITE
[47] Speed Master PAUSE OFF
[9] Cue List GO + Start
[22] Autofade
[48] Speed Master Pause Hold
[10] CF Color-fade color RED
[23] Freeze Main Output
[50] Fade type XF Cross-fade
[11] CF Color-fade color GREEN
[24] Add to Cue List A/B
[51] Fade type WF White-fade
[12] CF Color-fade color BLUE
[28] Crossfader Skip A/B
[52] Fade type BF Black-fade
[13] CF Color-fade color WHITE
[29] Must be value “mas.”! If “A” or “B” is selected, select “mas.”, then disconnect and reconnect the VCI100.
[53] Fade type CF Color-fade
