Numark NuVJ - MIDI Map
[9] Switch to Layer mode / Storage mode
LAYER MODE
STORAGE MODE
[1] Direct access for Layer 1 - 9
[1] Direct access for Storage Place 1 - 9
[2] + [4] Skip Layer UP/DOWN
[2 + 4 hold] Fast forward / fast rewind
[4] Pause ON/OFF
[6] Mix mode Layer UP/DOWN
[6] Storage Place UP/ DOWN
[6] + [Pressed] Set Mix mode Layer to normal
[6] + [Pressed] Add Storage Place to Cue List
[7] Submaster Layer
[7] Submaster Storage Place
[8] Opacity Layer
[8] Storage speed (Speed Master)
[10] Reset Submaster Layer
[10] Reset Submaster of Storage Place
[11] Reset Opacity Layer
[11] Reset Storage speed (Speed Master)
GLOBAL
                         [3] Master Fader or Audio level
                         [5] Cue List GO/Back
                         [12] NuVJ Dot Matrix Display
                         [13] Fade type UP/DOWN
                         [14] Cue List Open/Close
                         [15] Color Filter color RED
                         [17] Cue List Play/Pause
                         [18] Color Filter color GREEN
                         [19] Color Filter color WHITE
                         [20] Autofade
                         [21] Color Filter color BLUE
                         [22] Crossfader
                         [24] Fade time
