MADRIX 2 Help and Manual
Contents
| Index
2
3
4
8
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
*.csv
*.dxd
*.log
*.m2l
*.macs
*.mas
*.mcm
*.mct
*.mdf
*.mef
*.mfl
*.mfx
*.mit
*.mmrc
*.mms
*.mpf
*.mpl
*.mrec
*.ms2
*.mss
*.rtc
*.rtu
*.vdf
- 2 -
2022
24 FPS
25 FPS
- 3 -
30 Drop
30 FPS
- 4 -
4-Port DMX
- 8 -
8-Port DMX
- A -
A
Acclaim Lighting
ACN CID
ACN E1.31
Activate "Audio"-Button
Activate Audio Button
Advantages of LEDs
Akai Professional
Always On Top
AND
APC40
Apple
Artnet
Art-Net
Art-Net interfaces
Art-Net Remote
Art-Net Time Code
ASIO
Aspect Ratio
Audio
Audio Analysis
Audio Controls
Audio Device
Audio Input
Audio Input Configuration
Audio Level
Audio Performance
Automatic Fade
Avi
- B -
B
Back
Backup
Backup System
BCD2000
BCD3000
BCF2000
BCR2000
Behringer
BF
Bitmap
Black
Black-fade
Blackout
Blend
Blending
Blind Mode
Blocked
Bmp
Bob
Bob Linear
bottom:
BPM
Broadcast
- C -
CF
Channel Filter
Char
Check for BETA Update
Check for Update
Circle of Fifths
CITP
Clear
Clear All Storages
Clear All Storages A
Clear All Storages B
Clear Message
Clock
Close
Color Burn
Color Control
Color Depth
Color Dodge
Color FaderBox
Color Filter
Color Kinetics
Color Picker
Color Ramp
Color Table
Color-fade
ColorKinetics
ColourSmart Link
Commands
Config By Web
Configure device...
Console
Cont. Text
Control Panel
Conversion
Copy
Copy Storage Places
Cosine
Count Of ACN Devices Used
Create a new layer
Creative
Cross-fade
Crossfader
Cue
Cue All
Cue All Occupied Storage Places
Cue List
Cue List Section
Cue List With Duration and Date
Cue List With Time Code, Duration, And Follow Cue
Cut
- D -
Darken
Darker Areas
DaScratch
Daslight
Data Files
Datagate
Datagate Mk2
Date
Deinterlace
Delete
Demo mode
Description Field
Device Driver
Device Manager
Devices (Network)
Devices (USB/PCI)
DI
Difference
Digital Enlightenment
Digital Multiplex
Digital Visual Interface
Direct IP mode
Direct3D
DirectX
Disable Preview
Discard
Display Area
Display Rotation
DivX
DJ Console MK2
DJ Console Rmx
DJ Control MP3
DJ Control MP3 e2
DJ/VJ console
DMX
DMX Addressing
DMX Devices
DMX Fader Tool
DMX Input
DMX output device
DMX Start Channel
DMX Start Corner
DMX Start Universe
DMX Thru
DMX Watcher
DMX512
DMX512 interfaces
DMX-IN
DMX-IN - Large Protocol
DMX-IN - Micro Protocol
DMX-IN - Mini Protocol
DMX-IN - Small Protocol
DMX-IN - Universal Protocol
DMX-IN - Universal Protocol 2
DMX-IN Device
DMX-OUT
Dongle
DPI
drag & drop
Duplicate
Duration
DVI
DVI configuration
DVI devices
DVI Fixture
DVI Fullscreen
DVI Map
DVI Map Mode
DVI Mapping
DVI output
DVI Patch
DVI wall
DVI Window
DVI Window (Borderless)
DVI Window Settings
DVI, Window, Fullscreen
dxd
- E -
e:cue
e:net
E1.31
Edit
Edit Record
Effect Area A
Effect Area B
Effect Pipelines
Effects
Effects - Overview
Elation Professional
Enable
Enable ACN E1.31
Enable full size
Enable manual frame time
Energy Saver
ENTTEC
ENTTEC Datagate
EQ
ESTA
EUROLITE
EuroLite T9
event
Examples
Exclusion
Exit
Extension Ports
External
- F -
F.Cue
FADE
Fade Area
Fade Time
Fader
File
File Watcher
Files
Filter
Fixture
Fixture Editor
Fixture rotation
Fixtures
Flash device
Flip Horizontally
Flip Vertically
Flipping
FLV
FPS
frame
Frame Fade
Frame time
Free MIDI Assignment
Freeze
Frequency
F-Time
Full Frames
Full Size
Fullscreen
- G -
Gif
GLP
Go
GoTo
Graphical User Interface
Grid
GUI
- H -
Hard Light
Hard Mix
Height
Help
Hercules
Highlight device
Host Name
Hotkeys
HowTo
HTP
HTTP
- I -
Image Resolution
Images
Initialize QuickTime At Startup
inoage
Input
Input Protocol
Insert
Insta Light2022
Insta network driver
Installing the Software
Insta-Net
Interface
Interlace
Internet Browser
Interval
IP address range
- J -
JPEG
Jpg
- K -
Key
Keyboard Layouts
Keyboard shortcuts
Keyboards
KiNet
KiNet network driver
KORG
- L -
Large Protocol
Launchpad
Layer A
Layer B
Layer Button
Layer mixing
Layer mixing modes
Layer Opacity
Layer Tab
Layers
LED Fixtures
LED Matrix
LED Screen
LED Studio
LED Wall
LEDs
Ledwalker
left:
Light Matrix
Lighten
Lighting Console
Lighting Desk
Lighting fixtures
Linear Burn
Linear Dodge
Linear Light
Link
Link Mode
Linking layers
Live Mode
Livid Instruments
Load A Special Fixture Library
Load Audio Settings
Load DMX Device Settings
Load DVI Device Settings
Load Patch
Load Setup
Load This Setup On Start
Lock Position
Logfile
Logo
LTS
Luminex
- M -
M2L - Music2Light Effects
M2L Color Fade
M2L Color Rings
M2L Color Scroll
M2L Interval Drops
M2L Interval Tubes
M2L Single Tone Shapes
MAC To IP
Macros
MADRIX
MADRIX 3
MADRIX Fixture Editor
MADRIX GUI
MADRIX KEY
MADRIX Logo
MADRIX NEO
MADRIX PLEXUS
MADRIX Restore
MADRIX Time Code Sender
Main Mix
Main Orientation
Main Output Macro
Major
Map
Map Channels
Mapping
MAS Script Effect
Mask
Mask Mode
Master / Slave
Master Fader
Master Intensity
Matrix
Matrix Generator
Matrix size
M-AUDIO
Max. count of e:net universes used
Micro Protocol
MIDI
MIDI Map
MIDI Remote Control
MIDI Remote Editor
MIDI Time Code
MIDI Universal
MIDI Watcher
MIDICON
MIDI-IN
Mini Protocol
Minor
Mix mode
mix modes
MMC-1
MONACOR
Monitoring
Mpg
mrec
MSEX
MTC
Multiple fixtures
Multiply
Music Theory
- N -
Name
NAND
nanoKONTROL
NEO
New
Nicolaudie
Node 8
NOR
Normal
Novation
Numark
NuVJ
- O -
Offeset X,Y
Ohm64
Omni Control
Omnitronic
On-screen capturing
Opacity
Open
Open Options
Open Setup
Open/Close With Touch On MADRIX Logo
Operating System
Optimized Frames
Options
OR
Orientation
Output
Overlay
Oxygen 8 v2
- P -
Paste
Patch
Patch size
Pause
PC Configuration
PC-MIDI
Peak
peperoni-light
Performance
Philips
Picture Resolution
Pictures
Pin Layout
Pin Light
Pitch
Play/Pause
Playback
PLEXUS
PLEXUS Conversion
Position
Post Sync
Power Management
Power Options
Pre Sync
Preferences
Preview A
Preview B
Preview DVI 1
Preview DVI 2
Preview Images
Preview Output
Previews
Problems
Processor
Prodikeys
Projector
Proprietary DVI Devices
- Q -
Quicktime
- R -
RAM
Record
Recording
Remote
Remote Control
Remote HTTP
Remote members
Remove device
Remove/ delete a layer
Rename
Rescan for devices
Reset
Reset Previews
Reset To Default Settings
Reset To Fail-Safe Settings
Reverse Sentence
Reverse Words
RGB8
right:
Robe
Robe StageQube234
Rotation
RTC file
Run MADRIX, when Windows Starts
- S -
S2L - Sound2Light Effects
S2L EQ Drops
S2L EQ Shapes
S2L EQ Tubes
S2L Equalizer
S2L Frequency Flash
S2L Level Color
S2L Level Meter
S2L Level Ring
S2L Waveform
S2L Wavegraph
sACN
Save
Save Setup
Save Setup As
Scale
SCE - Static Color Effects
SCE Bitmap
SCE Bounce
SCE Color
SCE Color Change
SCE Color Fill
SCE Color Ramp
SCE Color Scroll
SCE Drops
SCE Explosions
SCE Fire
SCE Graph
SCE Metaballs
SCE Plasma
SCE Pulse/Stroboscope
SCE Radial
SCE Shapes
SCE Starfield
SCE Ticker - Scrolling Text
SCE Video
SCE Wave
Scenes
Screen
Screen Resolution
Script
Script Editor
Script Effect
Scripting Language
Scripts
SCS.3d
SD card
Selecting an Effect
Send Broadcast
Send Direct
Sentence
Set Master Fader On Value
Set Timeout To Start Software
Setup
Show
Show Clock
Show Status Information
Sine
Small Protocol
Smooth
SMPTE Rate
Snake Mode
Soft Light
Software Protection Dongle
Solo Mode
Sound Card
Soundlight
Spacing
Speed
Speed Master
Square
Stand-Alone Mode
Stand-Alone Show
Stanton
Start Address
Start Cue List After Loading The Start Setup
Start Touch At Startup
State
Stealth Control
Stereo Mix
Storage
Storage A
Storage Area A
Storage Area B
Storage B
Storage Button Count
Storage Place
Storage Place A
Storage Place B
Storage Place Macro
Storages
Streaming
Streaming ACN
Stretch Pixels
Sub
Submaster
Subswitch
Sunlite
Support
Sync Mode
System Requirements
System Time
- T -
T9
Task Watcher
TCP/IP network
Text
Thumbnails
Tile
Time Code
Time to detect devices in sec.
Timers
Tonality
Tone Theoretical Parameters
Tones
Tools
Top Field First
top:
Torq
Total Control
Touch
Touch Screen
Triangle
Tutorial
- U -
Unicast
Universal
Universal Protocol
Universe
Update MADRIX KEY
Upgrade
USB 2.0
USB Software Protection
USBDMX.com
USBone
Use Automatic Fade
Use Background Image...
USER
User Interface
Using the Software
- V -
VCI-100
VCM-100
Version Upgrade
Vestax
Video
Video beamer
Videos
View Dir
Virtual DMX Universes
Virtual Matrix
Visualizer
Vivid Light
V-Sync
- W -
Watch
Watch This Cue List File And Reload If Changed
WDM
WF
White Adjustment
White-fade
Width
Window
Window Position
Window Size
Windows
WMV
Word
WYSIWYG
- X -
XF
X-NET 8
XOR
Xponent
