Keyboard Shortcuts (Hotkeys)
File - New
Ctrl+N
File - Open Setup
Ctrl+O
File - Save Setup
Ctrl+S
File - Save Setup as
Ctrl+Alt+S
Matrix Generator
F2
Patch (open and close)
F3
Device Manager (open and close)
F4
Audio Performance
Ctrl+Alt+A
Options
Ctrl+Alt+O
Cue List (open and close)
F7
Recording
Ctrl+Alt+R
Touch Screen (open and close)
F8
Full Screen mode
F11
Task Watcher (open and close)
F5
Logfile (open and close)
F6
DMX Watcher
Ctrl+Alt+D
MIDI Watcher
Ctrl+Alt+M
DMX Fader Tool
Ctrl+Alt+F
PLEXUS Configuration
Ctrl+Alt+P
MADRIX Help
F1
Moving the DVI fullscreen or Touch Screen Window to a different monitor
TAB
If the selected control is a button,
the button will be clicked.
If the selected control is a check box,
this toggles the check box.
If the current control is an option,
this selects the option.
If an edit field (Color Edits) is selected,
you can switch between the values 0 and 255.
SPACEBAR
Confirm your selection
ENTER
The equivalent to clicking the 'Cancel' button
ESC
Quit MADRIX or close a window
(Cue List, FaderBox, Macro Editor, ...)
Alt+F4
