Supported Sound Cards
About The MADRIX Audio Analysis
Exemplary Sound CardThe selected audio signal is being scanned and analyzed using functions of Microsoft DirectX®. If your sound card does not process and deliver requested data fast enough, problems with the sound analysis are likely to occur.
If you are having problems with the audio analysis, we suggest:
Check if you have clicked the "Audio" button, and if the "Audio" button is activated.
Check the Windows recording settings using the mixer control for your recording device.
Check the installation of drivers of your sound card as well as the installation of the Microsoft DirectX®-version.
Buy one of the latest sound cards with high quality.
In order to make sure that your sound card works properly, we suggest testing it with MADRIX:
Start the MADRIX demo version.
Activate the sound analysis via the Audio button while playing some music on your PC, for example.
Open the Task Watcher (Menu "Tools" -> "Task Watcher" or press "F5").
Check the entries "Audio Capture Frames (Is/Tar.)". The left side shows the current value, while the right box shows the target value.
