Map, Tile, And Rotation |
You can assign/map effects to a certain area of your matrix, i.e. relocate them. In order to do so, please use the "Map" button in the effect area. A new window will open.
Map
Several presets, such as "Full Size", "Double Size", "Half Size", "Top", "Bottom", "Left" ,"Right", etc. are already included and available via the quick select button below. "Mirror" is an option to mirror effects horizontally ("Mirror H"), vertically ("Mirror V"), and in a horizontal-vertical direction ("Mirror HV") or not ("No Mirror"). Negative values may be used, too. In this way, you can map an effect to an outer area. Equally helpful is the option to "grab" and move the colored map square directly with your mouse or to use the faders. If you have mapped several layers, a colored square will be displayed for each layer in addition to the currently mapped layer.
For example, it could look like this:
Tile
Several presets, such as "Full Size", "Double Size", "Half Size", "Top", "Bottom", "Left" ,"Right", etc. are already included and available via the quick select button below. "Mirror" is an option to tile effects horizontally ("Mirror H"), vertically ("Mirror V"), and in a horizontal-vertical direction ("Mirror HV") or not ("No Tile"). You can also choose to repeat the effect ("Repeat").
Rotate
