MADRIX Fixture Editor
LED fixtures are implemented using the MADRIX Fixture Editor. The fixtures are stored in the MADRIX Fixture Library (madrix.mfl).
The Fixture Editor is automatically installed together with MADRIX. You can access the tool or its documentation by calling up the shortcut in the Windows Start Menu or in the MADRIX installation directory.
Fixture Editor
Usage
With the help of the MADRIX Fixture Editor, you can
see how fixtures are integrated in MADRIX,
see how many and which fixtures are already included,
adjust settings to your requirements,
implement and add fixtures to the library yourself.
Please note: Always make a backup of the madrix.mfl before and after applying any changes.
When updating your MADRIX version, the Setup (Auto Installer) will automatically create a "madrix.mfl.bak". This file is a backup of your old MADRIX Fixture Library. Moreover, the Setup will overwrite the current madrix.mfl completely to update the library.
