SCE Wave
SCE Wave
With the SCE Wave effect displays a moving wave with a particular color.
Adjust the speed with the "BPM" slider.
"Length" sets the wave's width. You can influence the outcome further by using various directions and modes.
"Mode" directly influences how the wave is drawn. Do not hesitate to experiment with the settings. A description is given below.
SCE Wave Example
Sine with Absolute Values
This mode uses a sine wave with absolute values. Activating it, will turn the button green.
Sine Wave
This mode represents a sine wave. Activating it, will turn the button green.
Sawtooth Left
Select this button to activate sawtooth mode, which has its peak to the left. Activating it, will turn the button green.
Sawtooth Right
Select this button to activate sawtooth mode, which has its peak to the right. Activating it, will turn the button green.
Triangle Wave
This button activates triangle wave. Furthermore, you can adjust the slider "Peak". By default, this slider is set to 50, which is the middle position. If you set it to the far left, a sawtooth with a peak to the left will be shown. If you set it to the far right, a sawtooth with a peak to the right will be shown. In this way, you can create your individual wave with values inbetween. Activating the button will turn it green.
