SCE Metaballs
SCE Metaballs
The SCE Metaballs effect displays objects that morph into each other creating a liquid animation.
SCE Metaballs Example
The Color Table defines the number and type of colors used by the effect. You can use more than one color for the effect.
"BPM" defines the speed of the effect.
"Count" defines the number of objects (metaballs).
"Max. Size" affects the maximum magnitude of the metaballs.
"Outer Glow" determines the outer shimmer of objects.
"Inner Glow" determines the inner gleam of objects which are not filled.
"Border" adjusts the border size of non-filled objects.
ModesNext to the "Max. Size" slider, a drop-down button provides several modes on how the size of the metaballs is calculated.
Uniform - Each metaball has the same size.
Linear - A linear distribution is used to increase the size regularly.
Quadratic - The majority of metaballs will be smaller than the rest.
SQRT - Using a square root function the majority of metaballs will be larger.
Cubic - Uses a cubic distribution with mixed sizes.
Random and Scale ButtonThe "Rnd" button (random mode) can be tapped to generate new random sizes each time. This automatically activates "Random" mode. Use the "Scale" slider for resizing. This slider is only available in random mode.
More ControlsIn addition, you can choose from different shapes (Rectangle, Rectangle Filled, Circle, Circle Filled, Diamond, Diamond Filled). A second button allows you to choose a second set of metaballs in cirlce, rectangle, or diamond shape. A third button defines how much the colors are mixed within the morphing objects (Very Blurry, Blurry, Slightly Blurry, Medium, Slightly Clear, Clear, or Very Clear).
