SCE Bounce
SCE Bounce
The SCE Bounce effect renders bouncing lines. As set-up possibilities you have got parameters for "BPM" (Speed), number of "Objects" and "Points", "Fade Out" time, and "Size". With the help of the Color Table you can define the colors of bouncing objects.
If a value of 1 is selected for "Points", various modes, such as rectangle, circle, and cross, are available.
SCE Bounce Example
You can either enter values directly over the keyboard or use the fader box with your mouse. With the "Reset" button you can set this effect back to default values.
