S2L EQ Shapes
S2L EQ Shapes
The S2L EQ Shapes are a real-time equalization of the audio signal using a variation of shapes to display tones of the music. By default low frequencies will be displayed at the bottom of the matrix and high tones at the top.
There are different parameters to set up different colors, BPM/fade, width of the objects, spacing between objects (pitch), size of their border, and various types of shapes.
S2L EQ Shapes Example
Available ShapesThe picture shows available modes/shapes for this effect. You have to play with the parameters BPM, Fade, Count, Width, and Border to see the possibilities you have with this effect. Be creative and try to combine this effect with others by using layers and different mix modes.
